89 Toyota Pickup Gas Cap Hissing
ADAMFABAREZ
Recently everytime I take off the gas cap it release a lot of pressure(in the form of a hissing sound) and a clunk is heard (sounds like the tank is returning to it's shape or something). Even if I run the car for a minute there is a pressure relief. And when the car is off there is a pressure relief even after it had just been relieved a minute before. I replaced the gas cap thinking that it wasn't venting, but that didn't work. Is this normal? If not what needs to be replaced or checked? Please help. :D
Mar 6, 2007 at 12:31 PM
  • 75,988 POSTS
Have the Evaporative system check from the charcoal canister to the fuel tank
Mar 6, 2007 at 10:02 PM
ADAMFABAREZ
thanks a lot, i'll try that.
Mar 7, 2007 at 5:00 AM
JOEMECHANIC
  • 28 POSTS
Most modern E.P.A.compliant vehichles are euipped with an anti evaporative fuel system,which is meant to keep the fuel vapors out of the atmosphere,these systems reuire a gas cap that has a total seal up to 14 psi.The hissing you are hearing is not pressure,but rather vacuum;air sucking back into the tank,to compensate for the physical volume of fuel which has been consumed,and the crunkle sound is often the large flat portion of the tank(the part most sensitive to changes in atmospheric pressure)returning to normal,almost all modern cars do this to some extent.
Mar 12, 2007 at 8:30 PM
