2007 Toyota Pickup shimmy
10,000 MILES • V8 • 2WD • AUTOMATIC
THENDER
I have a shimmy in the front end. It is noticable on uneven roads usally around 55 and up. When I drive on smoother roads, I do not feel anything. I took it back to the dealer and they said that it was a balance problem. They rebalanced the front tires, but it still has the same problem. Is this a problem with the 20" wheels on the Tundras? Can it be fixed?
Jan 11, 2008 at 7:18 AM
FISHERMAN
  • 937 POSTS
[quote:93a3439a14="thender"]Steering problem
2007 Toyota Pickup V8 Two Wheel Drive Automatic 10000 miles
I have a shimmy in the front end. It is noticable on uneven roads usally around 55 and up. When I drive on smoother roads, I do not feel anything. I took it back to the dealer and they said that it was a balance problem. They rebalanced the front tires, but it still has the same problem. Is this a problem with the 20" wheels on the Tundras? Can it be fixed?[/quote:93a3439a14]
Hello !!
Rotate the tires and see if that solve the problem...
but, you should ask the dealer to check it good!!
before the warranty expires !!
good Luck!!
Jan 11, 2008 at 8:00 AM
