2006 Toyota Pickup AC squeels
52,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRIAN DAHL
Our toyota has a AC problem. The AC compressor has a squeel in it. We have replaced the compressor and clutch and the new one did the same thing. We also replaced the AC filter. It still squeels. Is there something we are missing?
Jul 29, 2008 at 12:55 AM
KHLOW2008
  • 41,812 POSTS
Hi Brian Dahl,
Did you check the compressor, crank pulley and idler pulley alignment? They could be misaligned due to some distorting etc. Was the belt tension adjusted properly with the correct size belt?
Aug 23, 2008 at 3:45 PM
