2004 toyota tacoma throttle races while stopped.
2004 TOYOTA PICKUP
MACK3
2004 toyota tacoma pre-runner, 40,000 miles, V6, with cruise control and 4 doors, and NO floor mats.
I just bought this truck 3 days earlier from a toyota dealer, so i have no past history.
While stopped at a red light, with my foot on the brake, engine revved up, and rear wheels started spinning. I then with foot still on brake, put truck into neutral, and rear wheels stopped spinning, but engine started revving really fast. After a few seconds, I turned the ignition key off, then started the engine again and everything was back to normal.
I took it back to the dealer, they say they can't find anything wrong.
What is the likely cause of this? Cruise control malfunction, or something else?
Any help would be appreciated, so I can have more info when I talk to the dealer again.
Nov 13, 2007 at 2:50 PM
While stopped at a red light, with my foot on the brake, engine revved up, and rear wheels started spinning. What exactly do you meant by this-I don't get it. You're stepping on the brakes and the rear wheels are spinning.
Nov 13, 2007 at 6:06 PM
MACK3
[quote:c0220aa3e4="rasmataz"]While stopped at a red light, with my foot on the brake, engine revved up, and rear wheels started spinning. What exactly do you meant by this-I don't get it. You're stepping on the brakes and the rear wheels are spinning.[/quote:c0220aa3e4]
Correct. While stopped at a red light, with my foot on the brake pedal, engine suddenly revved up, and rear wheels started spinning. I had to push harder on pedal to keep from moving forward. I then put it in neutral, and engine rpm's went even higher, until i turned ignition key off. Like the cruise control engaged.
I've tried to google the web and found some info under "sudden acceleration" about either cruise control or electronic throttle causing problems.
Nov 14, 2007 at 1:02 AM
Here's your probable causes:
Clean out the throttle body/plate could be binding. Throttle position sensor and Idle air control valve. but try the TPS first, disconnect it and see what happens.
Nov 14, 2007 at 5:22 AM
