2003 Toyota Pickup WATER DRAINING INTO PASSENGER SIDE FLOOR
186,000 MILES • 6 CYL • 2WD • AUTOMATIC
JODYBLOND
I HAVE A 2003 TOYOTA TACOMA PRERUNNER TRUCK THAT WHEN USING MY AIR CONDITIONER, THE WATER IS DRAINING INTO FLOOR BOARD. AC IS GETTING COLD LIKE IT'S SUPPOSE TO BE. AFTER USING FOR A LITTLE WHILE, YOU CAN GO AROUND A CORNER AND YOU CASN HEAR WATER SLOSHING AROUND UNDER DASH. THEN BEFORE LONG IT'S IN THE FLOORBOARD. WHAT DO YOU THINK IS WRONG?
Jun 1, 2008 at 8:41 AM
WGATOR58
  • 5 POSTS
I don't know if this true for a Toyota, but my Ford had the same problem. Which is the area in front of the windshield, where the air comes into the car and the A\C use the same drain. This drain can some time get plugged up. I was lucky just forced alot of water down the front grill area which cleaned out the drain line. If this doesn't work, I don't have a Toyota repair manual yet, you may have to remove the inside fender well cover and get to the line to clean it out. Since I have a new Toyota pick-up I would be interested to know if this helped with your problem.
Jun 9, 2008 at 11:11 AM
