2004 Toyota Pickup black smoke running rough
41,000 MILES • 6 CYL • 4WD • AUTOMATIC
MEDIC
I am getting the worst fuel milage ever.when the trucks idles then I give it the fuel black smoke streams from the tail pipe the truck when driving sams to have a small miss .help what could be the problem
Dec 28, 2007 at 6:28 AM
  • 75,988 POSTS
Do you have a check engine light On or has flashed.
Rich mixture could be stuck in the open loop mode-being caused by the coolant temperature sensor or the snitcher oxygen sensor is not switching
Dec 29, 2007 at 6:31 AM
