2003 Toyota Pickup whinning noise in transmission
62,000 MILES • 6 CYL • 4WD • AUTOMATIC
ISLAND BOY
When my truck is on park or nuetral. There is no noise but when I put it into gear and step on gas, there is like a whinning noise under the shifter area. The noise is not so noticable but it is not normal.
Could you point to some problems/ repairs in this area. Thanks you
alex
Nov 16, 2008 at 10:35 PM
MMPRINCE4000
  • 8,548 POSTS
First check all fluid levels in transmission, differential and transfer case. Also inspect the above for leaks.
Nov 17, 2008 at 12:48 AM
