2003 Toyota Pickup gas tank shield
2003 TOYOTA PICKUP
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARC HEATH
The metal gas tank shield fell off due to extensive rust. It is in pieces. Do I need to replace it, and is this a job a handy homeowner with good tools can do himself?
Jul 16, 2008 at 12:57 AM
KHLOW2008
  • 41,814 POSTS
Hi Marc,
I would recommend replacing it as it prevents heat from the exhaust getting to the fuel tank and it won't be difficult to replace.
DO NOT weld if it is attached to the fuel tank edges, use rivets.
Aug 4, 2008 at 5:42 AM
