2003 Toyota Pickup 2003 Tacoma won't go in overdrive after
2003 TOYOTA PICKUP
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
A68CAPRICE
I changed the transmission filter and fluid in my 2003 Toyota Tacoma 2wd, with a 2.4L 4 cylinder. Now it will not go into overdrive. While I was changing the filter a tube that travels over the filter fell out , but I put it back in the way it came out. I checked the new fluid level after the engine warms up and I have set the parking brake and cycled the transmission through all of the gears (starting and ending in park). I have no idea what the problem might be. Any insight would be greatly appreciated.
Sep 9, 2008 at 2:43 PM
Check the coolant temperature sensor the computer uses its signal to provide overdrive in a given engine temperature.
Sep 11, 2008 at 11:38 AM
