2002 Toyota Pickup Why?
115,869 MILES • 6 CYL • 2WD • AUTOMATIC
CHICO23
  • 39 POSTS
I have a 02 Toyota Tacoma Double cab. I brought the truck 4 years ago from the huricane karina in louisanna, the truck was flooded complete, i changed the piston ring,and cleaning the heads. And started then one day i didn't want to start and it took a while for it to start, when its hot it starts right alway but when cold it does not start what is it please help
Mar 20, 2008 at 11:01 AM
SERVICE WRITER
  • 9,123 POSTS
You need to test it when the problem is happening. Fuel pressure should be checked and spark should be checked for a start. Something is going to be out of spec and give a clue.
There may be a case of a coolant temp sensor that is giving bad data to the PCM causing too rich of a condition.
Checking for codes in the history may be helpful.
Mar 20, 2008 at 11:07 AM
