2002 Toyota Pickup Not starting
PWRDBLUE
Engine Mechanical problem
2002 Toyota Pickup 6 cyl Four Wheel Drive Manual 102K miles
Truck will not start... when starting, engine turns over and does not want to 'catch' and run. Belts are all fine, including timing belt. Pressure is okay putting hand over oil fill cap. Although we do smell gas that is not being burned. Is this due to the spark plugs? We pulled spark plug cable off and first time it shot some sparks out, second time it did not. Car is due for 100K tune-up... gas filter change etc. Any thoughts?
Jun 12, 2008 at 10:55 AM
KHLOW2008
  • 41,812 POSTS
Hi pwrdblue,
It could either be the crank sensor or the distributor coil.
Remove distributor cap and crank to confirm rotor is turning while cranking.
Jun 14, 2008 at 5:05 AM
