Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Pickup
General
Fuse Test
2001 Toyota Pickup fuse removal
2001 TOYOTA PICKUP
65,600 MILES • 6 CYL • 2WD • AUTOMATIC
VAN ROCCO
MEMBER
1 POST
battery died. replaced battery. wont start. checked alternator 125 fuse, burned out. cant get old fuse out. major headache
Jul 8, 2008 at 4:44 AM
KHLOW2008
Experienced Mechanic
Hi van,
The fuse is attached with screws, remove them before you can take the fuse out.
When 125 A fuse blows out, you should check the alternator for shorting, unless you have installed the battery wrongly to cause it.
Jul 8, 2008 at 8:48 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
