2001 Toyota Pickup Correct tire pressure for best mpg
2001 TOYOTA PICKUP
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEVINTOY
Hello. I recently bought a 2001 4 cylinder toyota tacoma pre runner. What would be the correct tire pressure to get the best mpg. Everyone says different things. Thank you
Kev
Aug 10, 2008 at 12:25 PM
OBXAUTOMEDIC
  • CAR REPAIR CONTRIBUTOR
  • 3,711 POSTS
[quote:39b9c8a33b="kevintoy"]Tires and Wheels problem
2001 Toyota Pickup 4 cyl Two Wheel Drive Automatic 70000 miles
Kev[/quote:39b9c8a33b]
Hi Kevin,
There should be a sticker on the Driver door that will give you recommended tire pressures. However, if the vehicle has over sized tires for off roading then check on the tire itself. I keep all my tires oversized or stock between 32 & 35 psi.
And of course keep up the recommened service intervals.
Aug 10, 2008 at 1:01 PM
