2001 Toyota Pickup casues of overheating
2001 TOYOTA PICKUP
170,000 MILES • 4 CYL • 2WD • MANUAL
PICO11
my car has been overheating and it is getting worse. It overheats within 15 min of driving even with water in the radiator. Could this be a leak or other problem?
Sep 14, 2008 at 2:02 PM
  • 31,937 POSTS
Hi there,
There are a number of reasons that will cause an over heating problem, coolant leaks internal or external, faulty pressure cap, faulty thermostat, blocked radiator faulty thermo or viscus coupling fans. Have these check and you will find your problem.
Mark (mhpautos)
Sep 14, 2008 at 2:10 PM
