2000 Toyota Trundra
GREG OVERLOCK
When my wife starts he truck the check enginlight comes on the truck idles fast and there is no throtle response.
Jan 31, 2007 at 10:28 AM
SERVICE WRITER
  • 9,123 POSTS
So you press on the accelerator and no increase in idle? Any idea what code is in the computer?
Jan 31, 2007 at 11:24 AM
  • 75,988 POSTS
No throttle response-Try disconnecting the TPS and inspect it-you see anything? put it back in. Any improvement. Also while you're under the hood check the MAF sensor its attachecd to the air cleaner look in the flap, maybe something is stuck in there or need cleaning.
If not we'll be waiting for the OBD2 code in order to proceed on.
You sure the throttle cable is not disconnected-I heard of such thing the other day here. Lets check it.
HTH-Good Luck!
Jan 31, 2007 at 7:05 PM
SERVICE WRITER
  • 9,123 POSTS
Nice avitar Ras!
:P :D
Jan 31, 2007 at 9:26 PM
  • 75,988 POSTS
[quote:62c61358f7="Service Writer"]Nice avitar Ras!
:P :D[/quote:62c61358f7]
I've been trying to do this a long time-Thanks to you I finally got a pic in there.
Neat Huh! I'll be changing it once in a while Thanks again
Jan 31, 2007 at 11:27 PM
