2000 Toyota Pickup eratic idle at times
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
BDONEEYE
At times it idles perfect, then at times it almost goes dead.
no codes show up the scanner. We have replaced the fuel preasure regulator, tuned it up[plugs, plug wires, cleaned the throttle body] but still have the same problem. Your response would be appreciated. Thanks......
Aug 9, 2009 at 8:50 AM
  • 75,988 POSTS
Check the Mass airflow meter, idle air control valve, throttle position sensor and clean out the EGR valve
Aug 9, 2009 at 9:06 AM
