2000 Toyota Pickup
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
TRAINMAN1271
just recently started leaking oil (looks like gear oil) from in between the transmission and the transfer case. how much of a job is it to replace the seal between these two, or is there some other possibilities for causing the leak. I do not go off-roading (other than dirt roads), mudding, or any other form of torture. This is an everyday driver.
Sep 3, 2008 at 5:28 AM
KHLOW2008
  • 41,812 POSTS
Hi trainman1271,
Seals tends to age over time and is a wear and tear condition.
Book time for replacement of seal should be about 5.5 hrs.
Sep 13, 2008 at 5:17 AM
