1999 Toyota Pickup Starting
185,000 MILES • 6 CYL • 4WD • MANUAL
KYLEBERGEN
I have a 1999 Toyota Tacoma 4X4, V-6, Manual Transmission (best truck ever). When I push the clutch in to start,usually after it has sat overnight , I turn the key to start nothing happens. I replaced the clutch start switch and it worked okay for a couple weeks but now it has started doing it again. Any ideas?
Thank you,
Kyle Bergen
Aug 11, 2008 at 12:02 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
Aug 11, 2008 at 1:08 AM
