1999 Toyota Pickup door side panel
INSTRUCTIONS4US
Interior problem
1999 Toyota Pickup 4 cyl Two Wheel Drive Automatic
how to remove inside door panel
Nov 11, 2008 at 7:15 AM
  • 55,658 POSTS
Hi, yes to remove the door panel, first remove the window crank or window switch. Then remove the arm rest screws. Next, with a flate blade screw driver pop the lower push snaps at the bottom of the door panel. Once all of the push snaps are undone lift up on the panel, it will release from the top of the door frame, check this page it shows step by step.
https://www.2carpros.com/how_to/door_lock.htm
thanks for visiting
Nov 12, 2008 at 4:23 AM
