1999 Toyota Pickup clutch/transmission problems
190,000 MILES • 4 CYL • 2WD • MANUAL
MISSIONROOKIE
I can be stopped, with the clutch in and in first gear, and it will pop out of gear. It will also pop out of third gear.
What is wrong and can I, an amateur, fix it?
May 19, 2008 at 11:02 AM
  • 31,937 POSTS
Hi there,
make sure that the gear box is tight on the engine, check the gear shifter bush as well you may need your mechanic to do this. If theses ore OK, the fault will be deeper with in the gear box.
Mark (mhpautos)
May 19, 2008 at 10:42 PM
