1997 Toyota Pickup white smoke from tail pipe and foam in r
1997 TOYOTA PICKUP
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
REGGIE BRUMSEY
I make white smoke coming from my tail pipe after about 10-20 seconds after I started 2 weeks ago. So I changed the motor oil. The next day the smoke was gone. Two days later I drove To school, where ia about 10 miles away. When I got there I noticed that the water temp. gauge was higher than normal. The next day I checked the radiator and there was no coolant. I put in Prestone 50/50. I drove the truck to work the next day which is about 50 miles away. When I got to work the truck started to vibrate a little and then the check engine light come on. I truned off the car and went to work. At lunch I looked in the radiator, and there was weird colored foam coming from inside the radiator. I then started the car and the white smoke returned. I disconnected tyhe battery to see if the check engine light would stay off, it did. But, since I live so far, I called a tow truck. After my truck was removed from the tow, I started my truck, and to my amazement, the shaking was gone and the truck felt fine. So I test drove it, and it felt fine. Is it? Or what is the problem?
Mar 24, 2008 at 10:58 PM
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Mar 27, 2008 at 4:39 PM
