1997 Toyota Pickup Car overheating
1997 TOYOTA PICKUP
100,000 MILES • 4 CYL • 2WD • MANUAL
NYAWO MUSA
I own a toyota pick up diseal car. It overheat after a period of 10 km drive. Is the problem with the cylinder head or not?
Dec 3, 2009 at 6:07 PM
MERLIN2021
  • 17,250 POSTS
Do a compression leak down test, this way you will hear air come out of the exhaust, or bubles in the radiator, remove spark plugs, buy an air hose adapter for the leak down test, put the cylinder to be tested at TDC, attach thread air hose adapter into plug hole, attach air hose and check for leakage...or buy a radiator block test kit, they cost about 50.00 dollars US, this will check for hydro carbons in your antifreeze. Have you checked the cooling fan? Thermostat? Antifreeze level and strength? Excessive smoke from tailpipe?
Dec 3, 2009 at 8:37 PM
