1996 Toyota Pickup Stalls at idle
1996 TOYOTA PICKUP
93,000 MILES • 4 CYL • 4WD • MANUAL
GRIZROD
My Toyota Tacoma 4x4 2.7L four cylinder fuel injected, stumbles bad from idle once the engine is warmed up, and I try to take off from a stop sign. The engine will either stall or almost stall as it sputters. Have run a bunch of injector cleaner thru it, as the gas is not the best here in Guyana.
Is the MAF sensor going bad, am thinking about trying to clean it.
Thanks,
\Brian
Apr 11, 2008 at 1:39 AM
Do that and also the idle air control valve and throttle position sensor-
Apr 11, 2008 at 5:13 AM
