1996 Toyota Pickup less power
162,300 MILES • 4 CYL • 2WD • AUTOMATIC
PCWINGS
why does my 1996 tacoma run better cold than at normal temp , this truck has the best of every thing , don .I'm running 87 oct , 5/30 mobil 1 , new wires , cap , rotor , all filters ,mobil 1 trans fluid and e3 spark plugs.my problem is that i dont have the acceleration hot as i do cold , is this a bad fuel pump ?
Apr 20, 2008 at 2:32 PM
  • 55,616 POSTS
First scan the ecm for troble codes follow this link. https://www.2carpros.com/dia/index.htm it sounds like you have a ecm coolant temp sensor that has gone bad, please check it out and get back to me.
Apr 20, 2008 at 3:16 PM
PCWINGS
ok, i will , don pardew. thank you .
Apr 20, 2008 at 4:19 PM
  • 55,616 POSTS
np. :-)
Apr 21, 2008 at 7:25 AM
