1996 Toyota Pickup engine stalls
1996 TOYOTA PICKUP
TOYMAN
Engine problem
1996 Toyota Pickup Two Wheel Drive Manual 154129 miles
i have a toyota tacoma 1996. it has 154000 miles, 2.4L. i start engine an will run for a little bit an jus stall its self out, if i try to give it gas it will backfire.
if i keep it at hight rpms,like at 4000 it will do fine but when i back off i will go to idle for jus a lilttle bit and then just stalls.
Dec 1, 2007 at 3:33 AM
JAYKAPPY
I am having the same issue. It wasnot bad at first...it would idle at times but at other times die out. I found that if I gave it gas when starting it would be fine...then just hold the gas on to about 1500 rpm and it would be fine. Now all I can get it to do is start, it runs for 5-10 seconds and then dies. If I give it more gas it sputters and backfires a bit.
I know the engine is not shot....it was running great a few minutes before it wont run for prolonged periods of time.....
Could this bemy O2 sensor?
PLEASE HELP
Aug 9, 2009 at 3:44 AM
JBOLLINGER0
try checking ur fuel injecters could be clogged or ur plug wires or plugs. also could be your maf sensor try cleaning the contacts.
Aug 30, 2009 at 9:53 AM
