after I drive my truck about 15 miles my brakes build up pressure won`t allow the calipers to release!!!
Mar 5, 2008 at 8:01 AM
M8TRIX01
MEMBER
You could have a couple of problems. Do you know if it is both or one side? Problems are bad caliper. Or bad hose.
Mar 5, 2008 at 8:59 AM
BRIAN13G
MEMBER
I replaced the calipers. t seems to be the right front that is locking up .so you would try the hose then?
Mar 5, 2008 at 6:54 PM
M8TRIX01
MEMBER
if it is the right front lift the truck in the air then spin the wheel you should feel it dragging then open the bleeder screw if it stops dragging then it is a bad hose. if it doesnt it is the caliper or the mounting brackets or pins.
