I have a 95' toyota 4x4 with the v6. It bogs (feels weak) and hesitates after shifting gears under acceleration but then picks up when it hits a certain rpm and seems ok. It idle's fine, there is no backfire. I changed spark plugs & wires, cap, rotor, fuel & air filters but still no change. Timing is w/in specs. What else can i check? Thank you
Feb 20, 2010 at 12:41 PM
