1995 Toyota Pickup No Spark, help please..
1995 TOYOTA PICKUP
199,880 MILES • 4 CYL • 2WD • MANUAL
KACKMASTAH
So, i've got no spark. Ran several spark tests. Replaced the distributor cap and rotor, checked the Ohms on the ignition coil and checked the power from the battery up to the distributor (checked out fine). I'm reading the haynes and cant seem to find the ignitor on the truck, that would be my next troubleshooting project. Any suggestions?? am I doing anything wrong have i overlooked anything??
Aug 6, 2008 at 3:46 PM
Test the pick-up coil/s in the distributor, if okay-test the ignitor/wiring/computer.
Note: The pick coil produces the Ne and G signals as engine speed and piston positions when computer picks up these signals, the Comp will issue an Igt signal to the ignitor to fire the coil, when combustion occurs the Comp should receive an Igf signal indicating the combustion has occured and the whole process repeats-
Aug 6, 2008 at 8:08 PM
