1995 Toyota Pickup lights
158,000 MILES • 4 CYL • 4WD • MANUAL
GARRETTSMG
I have an issue with my lights.When I am changing from high to low beam or vise versa, they will black out randomly for a second untill I switch back to a different setting. some one suggested a loose ground. I am not sure if each light is ground seperatly or where it is located. Thanks for any info
Aug 14, 2009 at 2:39 PM
  • 75,988 POSTS
Check and test the headlight relay. The G200 ground point is at the left kick panel with the white and black wire
Aug 14, 2009 at 8:12 PM
