1995 Toyota Pickup Clutch problem
1995 TOYOTA PICKUP
19,500 MILES • 6 CYL • 4WD • MANUAL
MONTE JONES
For some reason, after the vehicle has set for several days, I have to pump the clutch many times to get it to work.
There is plenty of fluid in the master cyl. I don't see any leakage.
Should I start by replacing the master cyl?
Thanks
Jul 15, 2008 at 4:03 AM
KHLOW2008
  • 41,814 POSTS
Hi Monte Jones,
Yes, that is what you should do but why not spend a little more and get the slave cylniders replaced too.
When one goes, the other should not be too far behind.
Jul 15, 2008 at 4:46 AM
