I HAVE A 1995 T-100, EVERYTIME I GO TO ENGAGE THE PEDAL FOR SOME REASON ABOUT HALF WAY THE PEDAL CONTINUES GOING ALL THE WAY DOWN......... WHY?
Feb 27, 2008 at 11:10 AM
✓Experienced Mechanic
Check for a leak-No leaks bleed the clutch master cylinder and then the clutch servo-if it continues do something with the clutch master cylinder hydraulic pressure is created from the point.
