1995 Toyota Pickup Can't pass smog
1995 TOYOTA PICKUP
311,800 MILES • 4 CYL • 2WD • AUTOMATIC
NOUNH
my car cant pass califorina smog test. I keep putting antifreeze coolant on the ratiator every morning when I go to work. Every time I need to fill it back up. I need help to trouble shoot this problem. Any suggestion or advice?
Jan 15, 2009 at 9:30 AM
KHLOW2008
  • 41,814 POSTS
Hi nounh,
There must be a leak somewhere causing coolant sonsumption. Is the reserve tank drying up as well or is it overflowing?
Can you provide a smog test result so that we understand what is casusing the problem?
Jan 18, 2009 at 4:17 AM
