1995 Toyota Pickup brakes
218,000 MILES • 6 CYL • 2WD • AUTOMATIC
BEKNCAL
Hi there, I had both calipers replaced and checking the brake fluids and flushing the lines because of braking problems. My mechanic suggested that I have two new tires and rotate and balance done to my truck. While having this done, the new place determined that I needed two new brake lines from Toyoto. The truck was pulling to the left when I brake hard. All this was done and the mechanic said it was fixed. We drove it back to the mechanic and he rotated and balanced the two back tires and flushed the brake line. Still pulled to the left hard. He changed the metal connector and reflushed the lines, drove the truck and told me it was fixed. I still cannot drive the truck without pulling into the left lane when I apply the brakes. They say all the joints, shoes etc. look good. I need help please. I have spent 4 days without my vehicle. Thanks
Jun 5, 2008 at 4:26 AM
BLACKOP555
  • 10,386 POSTS
tkae the vehicle for a ride without using the brakes hard or fast, just a simple ride with a few easy stops then when you get home jack up the vehicle and feel the rims, do you notice any of the brakes are hotter or one significantly cooler than the rest?
get back
Jun 5, 2008 at 6:18 AM
