1995 Toyota Pickup blogged up
167,890 MILES • 4 CYL • 4WD • MANUAL
BROS
My trunk had been run rough, feels like it going to stall when it got warm, it's idle normal, wild driving it's jerking it wont even want to go. I had replacing spark and wires, and mass air flow, still didnt fix the problem.
Feb 8, 2008 at 7:21 AM
  • 75,988 POSTS
Try testing the throttle position sensor and also check the fuel pressure
Feb 8, 2008 at 7:26 AM
MGROSZ7M
  • 5 POSTS
I HAVE A 1988 TOYOTA PICKUP HAD THE SAME PROBLEM COUPLE YEARS AGO HAVE A MECHANIC CHECK YOUR FUEL FILTER IF IT GETS CLOGGED IT WILL
JERK STALL YOU NAME IT...TRUCK NOT GETTING RIGHT AMOUNT OF FUEL HOPE THIS HELPS YOU :P
Feb 10, 2008 at 1:56 AM
