1995 Toyota Pickup AC doesn't work.
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
SNOWGORILLA
My A/C stopped working. The fan/blower still works but the A/C(as well as the light for it) doesn't work or blow a/c air out of it. I checked the fuse and replaced it. It worked for 3 seconds and then it stopped. What do you think is the problem with it and what steps could I do without having to go to the shop?
Sep 8, 2008 at 2:54 PM
KHLOW2008
  • 41,812 POSTS
Hi snowgorilla,
Check the compressor clutch coil for shorting. Disconnect the compressor connector and see if the fuse blows when AC is turned on.
Sep 13, 2008 at 6:49 AM
