1995 Toyota Pickup 95 toyota pickup 4 cyl
1995 TOYOTA PICKUP
67,000 MILES • 4 CYL • 4WD • MANUAL
RUNNER17_1
  • 5 POSTS
The truck seems to die out and jump when I accelerate I changed out the oil and the fuel filter and it still does it
Feb 14, 2009 at 8:52 AM
Could be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Feb 14, 2009 at 8:16 PM
