1995 Toyota Pickup 4 wheel drive
160,000 MILES • 4 CYL • 4WD • AUTOMATIC
GRABBBER
When shifting from 2-H to 4-H the lever seems to work ok but the 4 wheel drive indicator light does not come on and the front end is not engaging. $-L does not work either. The fuse in the dash panel looks good. What else can I check? Thanks
Jan 1, 2008 at 11:29 AM
2CARPRO JACK
  • 11,533 POSTS
You will need a meter to figure this out.Start by checking continuity at the selector switch for proper operation If it working the actuator is most likely the problem
Jan 2, 2008 at 6:27 AM
