1995 Toyota Pickup 1995 Toyota Pickup Charging Issues
1995 TOYOTA PICKUP
287,000 MILES • 4 CYL • 2WD • MANUAL
BIGD6401
I have a 1995 toyota pickup, I was recently driving in and the lights started to dim and the radio shut off, I assumed it was my alternator so I replaced it. I took it for a drive after i installed the new one and it did the same, So I had it checked and they said it was good, But I cant figure out whats going on with it, It only reads 12 volts while its running any suggestions would be great..
Dec 4, 2008 at 3:38 PM
If its not 13.5 volts and above the alternator is not doing its job-get both the battery and alternator load tested. Double check all connections at Batt and Alty
Dec 4, 2008 at 3:52 PM
