1994 Toyota Pickup WHITE SMOKE
1994 TOYOTA PICKUP
199,000 MILES • 6 CYL • 4WD • MANUAL
HOBIE817
Last year i had a complete overhaul done (september) ran great in june of this year had fuel leak from fuel damper on back of engine by firewall which mechanic had to take entire intake off to access it, fixed. now the problem ,2 weeks after that temperatue rising on guage, coolant low, white smoke at start up, pulled the truck to mechanic sat about 2 weeks before he could get to it when he did every thing was fine no smoke no coolant loss no coolant in oil he ran it 2 weeks from his shop, let it idle for 3 hours every thing fine. changed radiator cap as a possibility and oil. I drove it for a week ran great but last night coolant spewed out of radiator resovior, white smoke, had to add a jug of coolant to radiator, slight missing, a real mystery, would do none of this with mechanic, I am taking it back to him this week any thoughts or suggestions to do ,that I can pass on to him. thanks
Aug 22, 2010 at 3:05 AM
KHLOW2008
  • 41,814 POSTS
Hi hobie817,
When there is white smoke with coolant losses, it could mean a bad head gasket.
Get apressure tst done to see if there is any leakages in the system.
Aug 22, 2010 at 4:17 AM
HOBIE817
thanks for reply
could somthing had happen (broke, moved intake gasket) when 2nd mechanic took off intake and put back on beause it was running great for months before and there are no visible leaks from coolant system on driveway besides that spew from radiator reserve thanks
Aug 22, 2010 at 5:16 AM
KHLOW2008
  • 41,814 POSTS
At the intake manifold there are coolant passages so it is possible for the gasket to leak. The leak could be minor so you would not notice.
Another possoble cause would be the thermostat. It could be stuck and that would cause overheating and the spewing of coolant into the reservoir.
A failing thermostat might sometimes work correctly and suddenly fails to work.
Aug 22, 2010 at 5:47 AM
HOBIE817
thanks for the info
could problem with intake gasket placement or something else under intake or bad thermostat cause the white smoke out of exhaust since there was no coolant in oil indicating head gasket. any thoughts why it was fine for 3 weeks no symtoms then all of a sudden went bad. would you pull intake to check and change thermostat. would that be good to suggest to mechanic. again thanks for your time
Aug 22, 2010 at 9:06 AM
KHLOW2008
  • 41,814 POSTS
If coolant is depleting, get a pressure test to check for leakages. It could save you a lot of time and unnecessary work.
Aug 23, 2010 at 3:42 AM
