1994 Toyota Pickup whats the deal?
1994 TOYOTA PICKUP
20,800 MILES • 4 CYL • 4WD • MANUAL
LPEREIRA
my 94 toyota pickup has been acting up since this summer. when I would be stopped at a stoplight, it would start to shake a bit, and the engine seemed to be pulsating. at first, the issue seemed to be a lack of coolant-but about a month after that issue was solved, the pulsating returned. my second visit to the shop involved the replacement of my radiator. again, my truck was good for a little over a month-and the issue returned AGAIN. brought it back to the shop, they said a "tube" was loose-fixed that, and once again, I am faced with the same issue about a month later-only this time, the engine seems to pulsate as I am driving and the truck shakes a bit when I am stopped-and my heater isnt working...aniy thoughts? I will probably take it to a Toyota Dealership this weekend to get their thoughts, but thought I would try you first....??
Dec 6, 2009 at 3:15 PM
Do you have a check engine light and when was the last tune-up?? Sounds like the problem is a lean or ignition misfire-check engine mounts if its loose
Dec 6, 2009 at 3:39 PM
LPEREIRA
great, will check it out-thank you!!!
Dec 6, 2009 at 11:27 PM
