1994 Toyota Pickup Trouble code 27 and now 21 and 27
COISC29
1994 Toyota Pickup 4 cyl Manual 225,00 miles
Check engine light on trouble code 27, replaced front o2 sensor, rear was replaced about 5 years ago, after replacing front sensor I now have 2 codes , 21 and 27; 21 = main oxygen sensor fault, 27 = sub- oxygen sensor signal or heater circuit fault. Would replacing rear sensor fix the problem ? or do I need to do something else....?
Sep 6, 2010 at 5:53 AM
DOCFIXIT
  • 18,828 POSTS
Are you using OEM O2s or after market?
Sep 6, 2010 at 6:20 AM
COISC29
The 1 front sensor that I replaced was a Walker oxygen sensor (aftermarket).
Sep 8, 2010 at 3:41 AM
DOCFIXIT
  • 18,828 POSTS
Did you have to cut wires and reconnect?
Sep 8, 2010 at 8:14 AM
COISC29
No the plug fit perfectly.
Sep 8, 2010 at 3:12 PM
DOCFIXIT
  • 18,828 POSTS
Several things can cause codes leak in air induction spark plugs injectors fuel pressure distributor wiring see schematic
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_610.jpg
Sep 9, 2010 at 3:12 AM
