1994 Toyota Pickup speedometer howling
DOTTIER
Noises problem
1994 Toyota Pickup 4 cyl Two Wheel Drive Manual
My speedometer works fine, no jumping around, seems pretty accurate on speed.
I starts howling about 45mph and gets worse as speed increases. Toyota parts guy says it doesn't have a cable so do I need a whole new thing or can it just be lubricated?
Thanks
Sep 18, 2010 at 6:18 AM
  • 75,988 POSTS
Yours is cable driven-Inspect the speedo gear and oil seal SPEEDOMETER GEAR OIL SEAL REPLACEMENT (2WD)
https://images.2carpros.com/forum/automotive_pictures/12900_speedometer_cable_1.jpg
(a) Using SST, remove the oil seal. SST 09921-00010 (b) Using SST, install a new oil seal. SST 09201-60011 Oil seal depth: 25 mm (0.98 in.)
Sep 18, 2010 at 9:58 PM
DOTTIER
Why would the parts dept at the Toyota dealer tell me it has no cable, just has a sensor?
It is a 1994 Toyota pickup. 2WD, manual trans, 4 cyl. 22RE.
Sep 19, 2010 at 3:00 AM
