1994 Toyota Pickup overheating and rough idol
TJSZOO
169,000 miles, 4 cylinder. Has always run great, it recently started rough idling when stopped I took it to a mechanic who speculated that the radiator (which was slightly leaking) and the thermostat needed to be replaced, he wasn't really sure. I went ahead and replaced them myself last night. Today it is continuously rough idling and overheating? Thanks for your help I really appreciate it!
Aug 31, 2007 at 4:27 AM
  • 75,988 POSTS
[quote:0a49fecb21="tjszoo"]169,000 miles, 4 cylinder. Has always run great, it recently started rough idling when stopped I took it to a mechanic who speculated that the radiator (which was slightly leaking) and the thermostat needed to be replaced, he wasn't really sure. I went ahead and replaced them myself last night. Today it is continuously rough idling and overheating? Thanks for your help I really appreciate it![/quote:0a49fecb21]
Warm engine up-shut it down-remove radiator cap-start it up-look into the radiator fill neck do you see coolant swirling around-now squeeze the upper hose for a few secs then let go-did it increase.
Could be a blown headgasket -white smoke coming out of the tail pipe-oil does it look milky-for the rough idle-coolant and the air/fuel are mixing causing it.
Check these areas and comeback we still got more to check
Aug 31, 2007 at 6:09 AM
