Lack of acceleration, chugging, hesitating, bogging, misfiring etc. could be caused by a clogged fuel filter or one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 29, 2010 at 7:50 PM
