1994 Toyota Pickup ENGINE DIES WHEN YOU PUSH THE GAS PEDAL
1994 TOYOTA PICKUP
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEVENKRAHN
I have a 1994 Toyota pickup with 240000 miles. The engine was rebuilt over a year ago and ran fine.The truck will start and idle fine but as soon as you touch the gas pedal it dies. It will start right back up and idle fine. You can even put it in drive while its idling and it will slowly drive under idle until you press the gas pedal and dies. The plug wires look fine. I have replaced the spark plugs and have a new battery. Any ideas on what I can check?
Jun 15, 2008 at 10:46 PM
KHLOW2008
  • 41,814 POSTS
Hi stevenkrahn,
I would suggest checking the following
1. throttle position sendor.
2. airflow sensor.
3. fuel pressure
Jun 18, 2008 at 3:31 AM
