1994 Toyota Pickup brake lights
10,600 MILES • 4 CYL • 4WD • MANUAL
FRANK MADEY
BRAKE LIGHT ON DRIVER SIDE STAYS ON OTHER SIDE DOES NOT LIGHT UP. BULBS ARE GOOD, PULL BACK ON BRAKE PEDAL SHUTS OFF LIGHT.
CHANGED THE BRAKE LIGHT SWITCH, NO HELP.
ALL LIGHTS WORK, TAIL, BACK-UP, SIGNAL.
ROOF LIGHT (EXTERIOR) IS BURNED OUT AND WILL REPLACE ASAP.
FUSES SEEM TO BE OK
Oct 5, 2009 at 4:00 AM
JDL
  • 16,098 POSTS
I'd have to check the bulb circuit that won't work for voltage and ground. If that checks out, the bulb isn't making good contact.
Oct 5, 2009 at 8:04 AM
FRANK MADEY
[quote:2cc61c4be8="jdl123"]I'd have to check the bulb circuit that won't work for voltage and ground. If that checks out, the bulb isn't making good contact.[/quote:2cc61c4be8]
I DO NOT UNDERSTAND......
ALL OF THE LIGHTS, TAIL LITES, BACK-UP LITES, SIGNAL LITES ALL WORK, FRONT AND REAR.
I REPLACED THE BRAKE LITE SWITCH, AND THAT DID NOT IMPROVE THE SITUATION. WHAT "bulb circuit that won't work for voltage and ground' ARE YOU TALKING ABOUT?
ALL THE LITES WERE CHECKED AND ARE GOOD, THEY WERE MOVED FROM THE LEFT SIDE TO THE RIGHT SIDE, AND THEY ALL MAKE CONTACT AND WORK,
WHEN I DEPRESS THE BRAKE PEDAL I DO NOT HAVE THE STOP/BRAKE LIGHTS LITE UP.
Oct 5, 2009 at 1:13 PM
FRANK MADEY
how did the reply to my question concerning brake
LIGHTS GET A RESPONSE SAYING, "I'D HAVE TO CHECK THE BULB CIRCUIT THAT WONT WORK FOR VOLTAGE AND GROUND"
I REPEAT ALL BULBS ARE N-E-W, THEY ALL WORK!
when depressing brake pedal, the drivers side brake light lights up, the other side (I.E.) passenger side, the brake light does not light up. the bulb is good!!!!
a donat will be made upon receipt of a solution to my problem.
thanx
FRANK
Oct 5, 2009 at 4:51 PM
JDL
  • 16,098 POSTS
Sorry for the misunderstanding, if the passenger side brake lite doesn't work, I'd check the wiring circuit for the passenger side brake lite. Donations are appreciated, but, I'll help any way I can, for free.
Oct 6, 2009 at 1:46 AM
