1994 Toyota Pickup acceleration problem
100,000 MILES • 4 CYL • 4WD • MANUAL
KEVIN WALLS
the truck has very poor aceleration up to 3400 rpm then it takes of like their is no problem if i unplug the tps, o2 or temp sensors it will run fine keep in mind i have already replaced the 02 with is brand new
Feb 24, 2008 at 9:55 AM
  • 75,988 POSTS
Test the closed and wide open throttle voltages of the throttle position sensor-could have a weak spot in it.
Feb 24, 2008 at 10:30 AM
