1994 Toyota Pickup 22re problems
JAREDLYMAN
Engine Mechanical problem
1994 Toyota Pickup 4 cyl Four Wheel Drive 120000 miles
my truck run erratic at around 2000 rpms like its missing, and when its at idel through 3500- 4000 rpms it has a rocker arm knock almost like the sound of a flat cam. i was told that the cam was good. also i was told the it could be the timming chain so i replaced everything with a whole new kit. im realy stumped what do you think it could be?
Apr 11, 2010 at 2:57 PM
JDAWG4CSA
have you changed your plug wires the could be jumping arc with each other or the electronic ignition is bad you should check the fire on each line with a light and alson on the coil wire
Apr 21, 2010 at 10:28 AM
