1994 Toyota Pickup
HEATHER_A
1994 Toyota Pickup
I have a 1994 Toyota Pickup and it will only crank with start fluid but will also run without it what could the problem be?
Aug 3, 2010 at 2:29 PM
  • 75,988 POSTS
Jumper the Fp and Batt terminal in the diagnostic check connector and see if it will start-let me know
Aug 3, 2010 at 5:53 PM
BIGGDAWG
Since it runs once you get it started, it sounds like it could be the fuel pump, and once it is started, it starts pumping.
Nov 2, 2010 at 10:59 AM
  • 75,988 POSTS
In the airflow meter block the vane flap wide open and attempt to start, if starts everytime the airflow meter is defective- The airflow meter grounds the circuit opening relay in order to power the fuel pump-
If there's a problem with the fuel pump I don't think it'll be running-check the fuel pressure to rule out the fuel filter and fuel pump-
Nov 2, 2010 at 11:16 AM
