1994 Toyota Pickup
1994 TOYOTA PICKUP
BOB4300
Engine Performance problem
1994 Toyota Pickup 4 cyl Two Wheel Drive Manual
cylinder #2 doesn't seem to be working, as the engine runs the same when the spark plug wire is connected or disconnected. I pulled the spark plug and cranked the engine and the plug does spark. It just happened yesterday as i was driving down the road. I replaced the spark plugs and wires, the rotor and distributor cap which did not help. Seems like it could be a fuel issue. Could an injector have gotten clogged? Any suggestions to fix this would be greatly appreciated.
Feb 2, 2010 at 5:25 AM
If its getting spark check the compression and injector on it
Feb 2, 2010 at 5:47 AM
